Premium surge protection, noise filtering, and voltage regulation for high performance AV systems.
Includes
- 6ft Gold Plated Coaxial Cable
- Rack Mounting brackets
- RJ11 Cable
- User Manual
Features
- Automatic Voltage Regulation (AVR)
- Building wiring fault indicator
- Cable Line Protection
- Coaxial/Cable Line Splitter
- IEEE let-through ratings and regulatory agency compliance
- Lightning and Surge Protection
- Noise Filtering
- Overload Indicator
- Phone Line Splitter
- Power Cord
- Protection Working Indicator
- Resettable circuit breaker
- Right Angle Plug
Output
| Number of Outlets |
12 |
| Receptacle Style |
NEMA 5-15R |
Input
| Nominal Input Voltage |
120V |
| Input Frequency |
47 - 63 Hz |
| Input Connections |
NEMA 5-15P |
| Maximum Input Current |
15A |
| Input Breaker Capacity |
15A |
Surge Protection and Filtering
| Surge energy rating |
5270 Joules |
| EMI/RFI Noise rejection (100 kHz to 10 mHz) |
50 dB |
| Peak Current Normal Mode |
80 (/PH) kAmps |
| Peak Current Common Mode |
160 kAmps |
| Dataline protection |
RJ-11 2-Way Modem/Fax/DSL splitter with protection (four wire dual lines),Co-axial Video / Cable protection,Coaxial 2-Way splitter with protection |
| Let Through Voltage Rating |
< 40 |
Physical
| Net Weight |
7.59 KG |
| Maximum Height |
95.00 mm |
| Maximum Width |
432.00 mm |
| Maximum depth |
241.00 mm |
| Shipping Weight |
10.18 KG |
| Shipping Height |
168.00 mm |
| Shipping Width |
518.00 mm |
| Shipping Depth |
322.00 mm |
| Master Carton Units |
2 |
| Master Carton Dimensions (Length x Width x Height) |
527 x 334 x 359 mm |
| Master Carton Weight |
22.27 KG |
| SCC Codes |
10731304 0 |
| Color |
Black |
| Units per Pallet |
36 |
Environmental
| Operating Environment |
-15 - 45 °C |
| Operating Relative Humidity |
0 - 95% |
| Operating Elevation |
0-3000 meters |
| Storage Temperature |
0 - 40 °C |
| Storage Relative Humidity |
0 - 95% |
| Storage Elevation |
0-15000 meters |
Conformance
| Regulatory Approvals |
CSA,FCC Part 15 Class B,FCC Part 68,Industry Canada,UL 1012,UL 1449,UL 498 |
| Standard Warranty |
5 year repair or replace |
