Improves Picture and Sound Quality
The PM8-AV’s Power Cleaning and Filtration eliminate common symptoms of contaminated power (including loss of detail, pops, hisses, hums and visual artifacts) and allows your A/V equipment to perform up to its full capability.
Surge Protection
Panamax’s Exclusive Protect or Disconnect™ circuitry. In the event of a catastophic surge such as lightning, it completely disconnects AC power to connected equipment.
Specifications
Weight 3.5 lbs.
Dimensions 12 in. L x 5 in. W x 1.75 in H (12.5 in. L Including brackets)
AC Power
UL 1449 Suppression Rating 500V
Thermal Fusing Yes
Single Pulse Energy Dissipation 1125 Joules
Response Time < 1ns
Protection Modes L-N, L-G, N-G
Protect or Disconnect™ Circuitry Yes
Peak Impulse Current 52,000 A
Maximum Current Rating 15 A (1800W)
Line Voltage 120VAC, 50/60Hz
Initial Clamping Level 200V Peak, 141V RMS
EMI/RFI Noise Filtration 45 dB(100 KHz - 1MHz)
Telco Protection
Wires Protected 2 wire, 1 pair (3,4)
Suppression Modes Metallic & Longitudinal
Fuseless / Auto-reseting Yes
Connectors RJ-11
Clamping Level 260V
Capacitance 30pf (approx.)
Universal Coaxial Protection
Shielded Yes
Insertion Loss < 0.5 dB
HD 1080 i/p Ready Yes
Frequency Range 0MHz - 2.2 GHz
Connections Female “F”, Gold Plated
Clamping Level 75V
Bi-directional Yes
| Height (inches) | No |
| Width (inches) | No |
| Depth (inches) | No |
| outlets | No |
| Voltage Regulation | No |
