Audioholics Home Theater StoreAudioholics Home Theater Store
item (0)
1-877-246-5427
Click to view full picture
Universal Remote Control RF20
SKU# RF20
Be the first to review this product
You could receive 50 Audioholics Points for writing a review and/or rating this product.
Availability: In stock
Earn 79 Audioholics Points
Retail Price: $119.99
Your Price: $79.99
The RF-20 universal and learning remote control can replace up to 10 remote controls and operate an entire A/V home entertainment system. The LCD screen device and function labels can be customized. Comfortable navigation via a combination of wear-resistant buttons and 5-way thumbpad for operation of menu-driven devices. The RF-20 has over 1,000 built-in codes for easy programming of products from all major brands. Because the RF-20 sends both IR and RF signals, consumers can take advantage of "whole-house" (through walls, cabinets and floors) operation by utilizing the optional MRF-100 RF receiver base station.
Features and Benefits
  • Transmits both IR and RF signals
  • Create custom text labels on the expanded LCD screen
  • Replaces up to 10 remote controls
  • Instantly access up to 40 favorite channels with the press of one button
  • Punch through operation for easy control of frequently used functions
  • Automate regular activities with 432 macro buttons, each with up to 190 commands
  • Retains programming without batteries up to 10 years
  • Works indoors or outdoors with the optional MRF-100 RF receiver
Specifications
  • LCD Size: .875" x 1.875"
  • Size: 8.5" x 2.5" x 1" (L x W x H)
  • Weight: 8 oz (with batteries)
  • Learning Capabilities: 720 IR commands at standard frequencies (15 kHz to 100 kHz)
  • Macro Capabilities: 472 macro and favorite channel buttons (up to 190 steps each)
  • RF Freq: 418 MHz
  • Range: RF - 50 to 100 feet / IR - 30 to 50 feet. Approximate range will vary depending upon operational and environmental conditions
  • Power Supply: 4 AAA alkaline batteries (included)
  • Warranty: One year parts & labor
Write Your Own Review
Only registered users can write reviews. Please, log in or register
Height (inches) No
Width (inches) No
Depth (inches) No
